Trans oil -MH44
Joe in Ontario
11-08-2004 09:05:18
Need to know where to buy 140 weight transmission oil for trans and rear-end of Massey Harris 44. I know it is black and heavy but cant find it anywhere here in Ontario. Thanks in Advance
Larry Martin
11-09-2004 15:51:48
 Re: Trans oil -MH44 in reply to Joe in Ontario, 11-08-2004 09:05:18
You can get 80W-140W from Tractor Supply.
Dave_Id
11-09-2004 13:13:31
You can use 80w-90 instead of the heavy black molassis. Might flow a little easier up there in cold country
Harris Guy
11-09-2004 16:16:29
 Re: Trans oil -MH44 in reply to Dave_Id, 11-09-2004 13:13:31
The 140 weight will give minimal lube to the steel gear set, in the coldest months; it's like frozen chocolate ice cream. If you saw it in a
bitter cold stretch, you'd realize the Winter use is wearing your gears. The 80/90 GL will seep
out the seals in warmer weather, but the 140 may
serve you better, in warmer seasons. A supply house is always a source for these items.
Joe in Ontario
11-09-2004 18:48:39
 Re: Trans oil -MH44 in reply to Harris Guy, 11-09-2004 16:16:29
Thanks Guys for the info so quickly. Joe
