NEED OIL PAN FO PERKINS GAS/WELD CAST IRON?
DOCPEPSI
11-07-2004 11:59:37
I HAVE A CRACKED OIL PAN ON MY 135 GAS PERKINS. LOW HALF OF ROD CAME THROUGH THE LEFT SIDE OF THE OIL PAN. I HOPE THE CRANK IS NOT BAD. ALSO CRACKED PART OF THE BLOCK. CAN YOU WELD THAT OR BRAZING? ENGINE# 371115000/2
Our Farmer
11-07-2004 14:14:09
 Re: NEED OIL PAN FO PERKINS GAS/WELD CAST IRON? in reply to DOCPEPSI, 11-07-2004 11:59:37
I've had good success welding cast with high nickel rod. Nomacast is one trade name. Preheating with a torch is important. Not cherry red, just enough to take the chill off. Slow cool under a blanket.
Could braze with a torch too, but I prefer weld.
