MF135 Power Steering Conversion
TRC
11-06-2004 06:38:11
I have a 1967 MF135 that I use around my small piece of property. It is an excellent tractor that runs well and does everything I want it to do. My only problem is that it has manual steering. For now I can manage the manual steering without any major problem, but I know that I'm keeping this tractor for many years and I also know that eventually I won't be able to handle it as well. Does anyone know where I might be able to buy a used power steering gear for this tractor so that I can convert it to PS? I have checked the add-on power steering companies and just don't like the product they have to offer. I'll listen to any ideas anyone might have.
David P, South Wales
11-07-2004 01:37:53
 Re: MF135 Power Steering Conversion in reply to TRC, 11-06-2004 06:38:11
Hi,
You might have problems with a PAS kit for a 1967 MF 135. The tractor will no doubt have a 'bent' axle. Later tractors from about 1969 s/n 140129 had a straight axle. My MF 135 parts book only lists a kit to fit the straight axle. The axle cylinder brackets may fit but you would have to check first. Hope this helps
David P
Gerald J.
11-06-2004 09:45:46
Finding and making the power steering parts work might be a problem. You will need a new steering column because the control valve is part of that. You will need a new top for the steering gear box and the cylinder that mounts on the front of that. You will need pump/reservoir and hoses. You should probably start with a parts book.
I've seen more 35 with the power steering tag but that had the power steering removed than any loose power steering parts.
I broke the piston rod on my MF-135 power steering. This was at least 12 years go. MF wanted $472 for a new cylinder assembly and something like $275 for the control valve and steering column. A local machine shop made new piston and rod and fixed the steering column for $125.
Gerald J.
