44 MH gear problem
WGS
11-06-2004 02:16:50
Finally got my early 1952 44 MH running after months of work. After about fifteen minutes of driving it around and going through all the gears,it stuck in either second or third gear. The shift lever moves sideways but won't take it out of gear. It is not stuck in two gears at the same time. The shift lever did seem sloppy but would go in any gear without forcing it. My first MH so I didn't what to expect.
Thanks for any comments.
WGS
msb
11-06-2004 19:23:12
 Re: 44 MH gear problem in reply to WGS, 11-06-2004 02:16:50
One of two thing or a combination of both.The end of the gear shift leever is worn out.Remove the boot and take the snap ring out.Then you can pull the lever out of the transmission.You might have to braze it up a bit.The other thought is the shift rails have come loose from the shifters or are worn out although this is unlikely.
WGS
11-08-2004 00:31:06
 Re: 44 MH gear problem in reply to msb, 11-06-2004 19:23:12
Removing the shift lever, repositioning the third gear shift rail and reinstalling the shift lever worked as advertised. It didn't appear to be worn nor did the shift rails. Thanks
WGS
