MF-35 Hydraulic Filter???
Dale in WV
11-05-2004 15:44:08
Just realized I first posted this on the HF site, so here it is on the right one
F-I-L's MF35 Diesel hasn't had hydraulic fluid changed in over 15 years (maybe more). The oil is a little off-color, not milky but then the tractor's been shed kept and never been exposed to wet weather. For a 1962, it has just over 5000 hours. He has an "owners" manual that came with the tractor -- somewhere.... ((I bought HIS brother's tractor and its tranny had oil almost white)). I saw a post on another site about a MF tractor with an internal hydraulic filter, safety wire to secure it , etc. -- is there an internal filter on this tractor, or do I just drain - drain - drain?? Its happening tomorrow. I've got the motivation, buckets and new fluid. Any help you can give wud be appreciated.
sibby(Aus)
11-06-2004 00:55:59
 Re: MF-35 Hydraulic Filter??? in reply to Dale in WV, 11-05-2004 15:44:08
Dale, Some later ones had a filter, not too many did. When you drain oil remove the left hand sideplate with the p.t.o. lever and you will see it through the hole if it has one. cheers. sibby.
