MF 35 Diesil Multi Power Trouble
ET
11-05-2004 06:35:15
I am going to fix a multi power in this unit. So far I have made sure the valve moves down all the way when it shifts but nothing happens. How do I do a pressure check on the system to see if the pump is doing anything? Is there an external port to check presure? Is the port in the clutch housing on the valve? I have been told I need to split the tractor and run the input shaft with a drill and have a gauge hooked on the valve body to see if the pump is doing anything.
Gerald J.
11-05-2004 06:59:23
 Re: MF 35 Diesil Multi Power Trouble in reply to ET, 11-05-2004 06:35:15
In my MF-135, the multipower system only has pressure when the multipower valve is in hi position.
You probably want to put new seals in the valve when you have it apart.
Gerald J.
