""I think your out of luck. "" I doubt that. If I wanted to I could weld one up myself.. all it is is lift and link arms, hyds, pins and mounting points. ""I don't know anyone or anywhere to get a 3pt hitch for these HM tractors.""
I've seen a few places over the years that make custom retrofits.. I just never saved their URL's as at that time.. all my tractors had 3pt. "" I find it surprising that no one makes a good after market setup for these tractors."" As vast as the tractor world is.. I'm betting someone does.. or has a unit that could be easilly adapted.. ""If you do come upon anything let me know I am also in search of a 3pt hitch for my MH 30. But, come to think of it I have never seen a 55 with a hitch on it ever. Mostly just pulling tractors. Good Luck "" Well, you can try the worksaver site.. or another one I found. I have the url at work and will post it here when I get their. For what it's worth.. I've seen a custom 3pt hitch on a tracked tractor.. was driven by a da cylinder that was mounted to a horizontal fixed lower crossmember, and pivoted on a hefty pin.. the top portion of the cyl pivoted on a pin that was on a rockshaft. On either side of the rock shaft were the 'upper lift arms'.. link arms connected those to 'lower lift arms' that were connected to that same lower member, on either side of the hyd cylinder. The hyd power was supplied by one of those 12v self contained hyd units mounted up by the operators platform, with the 2 hoses run back to the cylinder. Nice little setup.. all self contained resevoir and relief system, and the unit looked like it was simply made in a box fram as the rear support.. The rock shaft was mounted inside some heavy walled pipe that had nearly the same ID as the OD of the rockshaft. A couple grease fittings and it looked pretty decent for an obvious aftermarket fab up. Soundguy
