MF Gas 135 / oil leak
JWyatt NC
11-01-2004 16:57:36
I knew my tractor was needing some oil every now and then. Looking over it I noticed wet oil on bottom of oil pan and followed it up to the bottom of belt pulley. From what I've read in the IT manual it sounds like the front seal is bad, and to get to this I need to pull the front end of tractor away to get the timing gear cover off and put a new seal in. Does this sound right to you guys. As always, Thanks ya'll for the help.
Bob S
11-03-2004 18:32:27
 Re: MF Gas 135 / oil leak in reply to JWyatt NC, 11-01-2004 16:57:36
it looks like you mite get away with just removeing grill/rad stuff on front.but it would give you much more ''room'' by taking off front end, that way you can check front axle bushings and replace while you are there
