HELP,FE-35
TROY OF OHIO
04-08-2000 19:31:36
I AM NEW TO THE VINTAGE TRACTOR WORLD AND RECENTLY PURCHASED AN FE-35 MASSEY FERGUSON TRACTOR. I INITIALLY BELIEVED THE TRACTOR TO HAVE BEEN BUILT IN THE U.S., BUT HAVE NOW FOUND THAT IT WAS BUILT IN COVENTRY, ENGLAND. ARE PARTS(ORIGINAL OR REPLACEMENT) AVAILABLE FOR THIS MODEL. IS THERE ANYTHING THAT I SHOULD HAVE KNOWN ABOUT THE FE-35 OVER THE TO-35 MODEL PRIOR TO PURCHASING IT? MY MODEL WAS BUILT IN 1959 AND IS A FOUR CYLINDER DIESEL. THANKS IN ADVANCE FOR HELP YOU CAN GIVE.
TROY
04-09-2000 16:38:06
 Re: HELP,FE-35 in reply to TROY OF OHIO, 04-08-2000 19:31:36
JACK AND ELMER, THANKS FOR YOUR INPUT, I'M SURE IT WILL COME IN HANDY IN THE NEAR FURTURE. THE MANUALS THAT YOU BOTH HAVE SPOKE OF; I LOOKED THROUGH THE ONES LISTED FOR SALE TO THE LEFT ON THIS SITE, BUT ONLY FIND THE MF35 MANUALS. IS THIS THE SAME THING, AND IF NOT, WHERE CAN I OBTAIN THEM FOR THE FE35? IN REFERENCE TO THE ENGINE PARTS, IS THERE A SPECIFIC CANADIAN DISTRIBUTOR? THANKS AGAIN!!!
Jack in NB
04-10-2000 03:06:32
 Re: Re: HELP,FE-35 in reply to TROY, 04-09-2000 16:38:06
Hello Troy -
The I&T manual for the 35 (MF-14) covers the FE35 and Standard engine. Drop me a note on the other question.
Elmer
04-09-2000 05:54:00
I have the Massey publication of the shop manual and parts book. Also have the operators manual. If you would be interested in copies let me know.
Jack in NB
04-09-2000 03:31:13
Hello Troy -
You have an excellent tractor. Might take some fixing, but it will sure be worth it!
While it's vintage, it will give you more bang (or rather, Purr - the bang is painted green) for your buck than ANY of the new ones.
There is very little difference between the US and UK units - Lucas electrics, which can be replaced with delco if/when needed (we've replaced all our generators with $65 Cdn self-energizing 37 amp delco alternators), the steering box, and the first two letters in the serial no!
The only failure I've heard of in the steering is when a barn fell on one!
Speaking of the steering box, it would be a good idea to change the oil in it. It almost certainly has the original oil and can get crudded up. You have to take the side off the box to drain and flush it. Silicon will replace the gasket.
Strongly recommend a shop manual - we use the I&T publication MF-14. Available from our hosts. A bit cheaper than the MF shop manual, covers everything but the steering and Lucas. What the manual doesn't tell you, the folks on the board here can.
Most engine parts are readily available from Canadian sources.
The 4-cyl engine is reliable, a bit less power than the later Perkins, and will likely be hard to start in cold weather, and maybe even in warm.
We installed a 150 - 200 watt block heater in the lower rad hose on ours, and a half hour to an hour in winter, 15 min in summer did it.
Enjoy your new pet!
BILL
04-08-2000 20:18:50
The FE35 is a great tractor, Ihave one myself
