flow rate of 44 hyd pump?
Robin Mach
10-30-2004 18:04:17
anybody know what the rated flow/pressure is for the factory hydraulic pump on a '52 MH44?
thanks,
robin
cst
11-10-2004 07:59:59
 Re: flow rate of 44 hyd pump? in reply to Robin Mach, 10-30-2004 18:04:17
I have a 51 MH44 the owners manual states 8 gal per minute..
Robin Mach
11-10-2004 10:46:02
 Re: flow rate of 44 hyd pump? in reply to cst, 11-10-2004 07:59:59
thanks very much cst. that's the info that i was looking for.
Harris Guy
10-30-2004 20:02:10
'52 44's had a split in S/N's, early around 1100 PSI. The 40K series, by late '52, #42K,& up may
run closer to 1250, as Continental was updating cams, timing, for non-ag use of this engine, since the H277 was debuting in the Specials. Wise
to forget building a 3 point on a'52, nothing worked, until Hitch-All(cat.II), in mid '54, on
the Special.Earlier attempts were mere cultivator
lifts, modified, broken up by 44's. There are no '54 44's, only Specials. Your goal, a n Ford, stop playing with early MH hitches, waste of time
Bottom line:No Hitch-All, no 3 point function.
The trade of large old iron, for Ford small,costs
you money. Marlowe stated it, it is a fact.
Robin Mach
10-30-2004 20:39:19
 Re: flow rate of 44 hyd pump? in reply to Harris Guy, 10-30-2004 20:02:10
thanks Harris Guy. i'd say i've got the earlier, 1100 PSI pump. SN 44GR25943
