C. T. in Oklahoma
10-31-2004 14:28:45
Re: Need temp gauge for MF35 Diesel in reply to Rod in S.F. Ontario, Cana, 10-31-2004 13:06:36
Rod, I think your are on to something. Mine is a Brit diesel manufactured in Coventry, England also, but mine is, according to the following, a super or special which included a tractormeter, a dual clutch, differential lock, and temperature gauge. See the following that was posted by H. T. Hertz in June, 2003. "I was told, that FE35 is the designation of the model built at Banner Lane, UK. After the merger with MH, several of the names and logos were indeed changed, but not the basic design. This is why I mean that you are right all of you. My 62 '35 has FE35 on the transmission housing, MF-35 on the nameplate and casting marks. Further, here in Denmark there were no such thing as a Deluxe model. The UK model sold here, (and, I believe in all of Europe) were called Super or Special, the Super with dual clutch, coolant thermometer and tractormeter, the configuration to be seen from the serial number (SNMYW, SNMY, SGM, SHM etc.) As for the 35X it had the A3-152 instead of the 3-152 Perkins. As far as I know there were no AD3-152 (direct injected 45hp) versions of the '35.". Rod, what is your S/N? That might shed a little light on the subject. C. T.
