Response to Tran/Hyd fluid for MF 135 gas
JWyatt NC
10-29-2004 08:37:22
Got all your messages and found at Tractor Supply a Universal tractor fluid with all specs and makes on container. However it didn't specify MF 135 but did say MF 1135. I assuming it will work? Thanks again. By the way I've had the tractor for a year and I'm assuming the fluid hasn't been changed in a while. How would I know for sure whether to change it or not. Tractor has 2900 hrs on it I think. Thanks.
Big Dean
10-29-2004 14:12:11
 Re: Response to Tran/Hyd fluid for MF 135 gas in reply to JWyatt NC, 10-29-2004 08:37:22
Yes the oil for the MF1135 will work in the MF135.
Gerald J.
10-29-2004 10:13:32
the spec number is MF-1129A, not MF-1135. They may not be the same.
If the oil has gathered water, it needs to be changed, if its clean, it might not. Be sure to clean or change the hydraulic filter while changing the oil. Don't let the cup drop off the filter when removing it or you will have dropped a big bunch of the collected grunge right into the pump intake.
Gerald J.
Gerald J.
