MF135 low oil pressure
Jerry M
10-28-2004 16:36:53
have not had tractor long is my first tractor, it is mf 135 w/4cyl continental gas engine. gauge with no numbers was going about 1/3 up and then going all the way down. thought I might have a bad gauge bought one at auto parts store still did same thing no oil pressure up and down from 0-25 mostly down. I change oil and filter, thought I had found the problem filter spring and rubber seal was pushe up into oil filter think spring was put on upside down. still no oil pressure after oil change , took tube loose at gauge, only small amount comes out in squirts like air in line. I plan to pull oil pan next and check pump what do I look for?
Jerry/MT
10-28-2004 19:59:00
 Re: MF135 low oil pressure in reply to Jerry M, 10-28-2004 16:36:53
You may have a cracked oil pick up tube or the ol pickup tube may be loose. That's why its spitting air occaisionally. You'll have to drop the pan and look at the oil pick up. If you don't have one, get a good factory shop manual.
txblu
10-29-2004 07:03:11
 Re: MF135 low oil pressure in reply to Jerry/MT, 10-28-2004 19:59:00
Also, if you remove the pump and fool with it, insure that you get it primed before you reinstall. I put them in a cake pan full of oil and spin the shaft till it comes out the outlet then reinstall.
Mark
