Rod in S.F. Ontario Canada , come in
txblu
10-26-2004 12:03:59
Post was getting lost..... .my no brag just fact comments on the syrinity of the MF35 and Rhino.
If I read your reply correctly you said my comments pushed you over the edge to make the purchase.
Smart man. I wanted to share my enjoyment with you and hopefully you'll do it too. Looks like you did. Enjoy.
Mark
Rod in S.F. Ontario, Cana
10-26-2004 19:54:01
 MF 35 has arrived home! in reply to txblu, 10-26-2004 12:03:59
It turns out there are some perks to being a teacher. One of my students offered to haul my tractor home for $100. O.K. Several phone calls later and he had the thing loaded, 30 miles north of Smiths Falls. I waited near my home and he picked me up an hour later in the most lavish pickup truck I have ever seen: a newish GM 3/4 ton with a Cummins diesel, Alison transmission, pintle hitch, and an 18' flatbed behind all decorated with chrome. The tractor was well secured and the ride went very well. The guy had his cousin and his girlfriend along for the ride, but they made space for me in the navigator's seat (did I mention this thing had four doors?) and away we went.
The boys started the MF with insolent ease, backed it neatly off the trailer. No problem, at all. Mark said that normally these things leak so much they change their own oil, but this one seems fine. The cracked tire should last for a long time.
Sometimes do-it-yourself is just not the way to go.
More to come as I get acquainted with the beast.
Arthur from Tassy
10-27-2004 01:58:02
 Re: MF 35 has arrived home! in reply to Rod in S.F. Ontario, Cana, 10-26-2004 19:54:01
Hi there Rod
Well done! Ill be keeping a eye on any more postings.
by the way did you get a photo of the rig with the tractor on board?
Cheers Arthur from Tassy
10-27-2004 03:55:05
 Re: MF 35 has arrived home! in reply to Arthur from Tassy, 10-27-2004 01:58:02
Alas, I did not. I had the digital camera all ready to go, but forgot it while grabbing cell phone and flashlight.
10-27-2004 16:03:05
 MF 35 at home (long) in reply to Rod in S.F. Ontario, Cana, 10-27-2004 03:55:05
I had a chance to play with the new toy this afternoon. When I checked the fluids (convenient hatch on top) it had ample diesel and seemed a bit low on coolant. I could see the top of one of the tubes, but the others were covered. The culprit seems to be the top hose, which is weeping around the joint onto the engine. A clamp, I think.
Nothing vigorous for the MF today until I get more coolant. Transmission fluid shows some signs of water, and of course the engine oil is black. Fluids and filter to come. How about diesel filters? How often does one change them?
I know, I'll get to a dealer and order a manual, but I've been busy.
The tractor started very quickly in the 50 degree F weather, smoked a bit, smelled a bit, and then cleaned up as I revved it up and moved forward.
I drove it on a tour of the farm. This grew old quickly as it showed no inclination to do anything dramatic like backfiring, stalling, or drinking its own oil and racing away. It just ran smoothly along and smelled like a diesel. It has a nice, comfortable seat and a good ride. The low gears are wonderful, though. I was able to climb around some rough corners of the barnyard I didn't dare investigate with the Ferguson because of the high gearing.
On a whim I backed up to the bush hog and hooked on. It fitted fine. I had thought that the draw bar protruded too far to allow the bush hog to run, but it cleared it by a few inches.
Running with the rotary blades spinning (the unit's the same width as the tractor, 5' 6") the 35 seems to have ample power and lots of travel to adjust height on the lift.
I mowed some tricky areas around a woodpile and discovered the front wheels will slide sideways quite easily if one encounters a log submerged in the undergrowth. The difference between the 35 and the TEA 20 was that this time I didn't sprain a wrist from the impact because I was going so slowly. Major benefit, here. The TEA20 cost me almost three weeks of bass fishing two summers ago because of a wrist injury from an elm stump.
I won't say that running a bush hog has become fun, but it sure takes a lot less adrenaline with the 35 than the TEA20, and it does a much better job.
This model has the ground speed pto as well as the engine speed setting. Both work, though I can't see the point of the ground speed one yet.
I could use some gauges: the tach/hour meter is shattered at 5700 hours. There is no temperature gauge. Oil and voltage are fine.
Any suggestions? Do I need the gauges?
I took a hard look at the loader on the TEA20. Would it fit the 35? It's quite a recent model, I think, using very heavy tube steel for a frame on the tractor, twin cylinders, heavy arms and a trip bucket.
All in all I am delighted with the new tractor. It looks to me like something that will do a lot of work over a long period of time.
So now it's nestled in the barn with the fishing boats and the TEA20.
txblu
10-28-2004 09:30:47
 Re: MF 35 at home (long) in reply to Rod in S.F. Ontario, Cana, 10-27-2004 16:03:05
Not in order.
Gauges yes. Really want and need to know what the engine is doing.
Don't knock the fact that you might enjoy hoggin with it. I do.
The hood will lift up if you don't have a front bumper to get in the way. There is one screw on each side just behind the dash under the hood. Pivots just front of the front axle. Undo the screws and lift up. The air breather inlet (rubber hose) should just slide off the oil bath aircleaner air inlet. Really nice. Or do as you said and open the access cover.
Freq of diesel oil change: Up to you. If it has the cartridge filter, it is the NAPA 1188. Be sure and get all the seals installed correctly.
On the oil change, I'd change it, run it awhile with the mower to put some load on it then change the oil again. I also put a little MMO in the diesel to help limber up things that may have been sitting for awhile.
Noticed mine is using a little oil, but being a diesel, and no more than it's using, and the fact that it starts right up and is peppy, I can't see a need to go into the engine. Will just add oil as necessary and at least once a year change it and the filter.
Be sure and check the antifreeze safe temp while you're messing with the radiator and also, fluid only needs to be above the coils. Rest of the reservoir is for expansion you know.
Definitely do a total fluid change.
Good luck.
Mark
txblu
10-27-2004 07:02:56
 Re: MF 35 has arrived home! in reply to Rod in S.F. Ontario, Cana, 10-27-2004 03:55:05
Nice story.
Mark
