Massey Harris 50
Ian milne
10-25-2004 17:48:05
I am looking for info on my massey 50 hydraulic system, it has problems picking up on the 3pt hitch and has difficulty keeping any weight up, creeps down quite fast, can anyone give me some tips as to what may be the problem?
Big Dean
10-25-2004 18:37:47
 Re: Massey Harris 50 in reply to Ian milne, 10-25-2004 17:48:05
You have a leak in the system in most cases I have found it to be the pump control valve. That problem is usually a sign it is time to rebuild the pump. To check for a leak on the top side get the oil up to normal operating temperature drain the oil down below the bottom bolt of the access plates remove the access plate with the Tran/Hyd dipstick in it on the right side try to lift something watch inside for oil leaking from the top if you have a lot leaking from the top you have a cylinder problem. Look for heavy turbulence near the right rear corner of the pump that is an indication of a bad relief valve. If you do not have one of those problems it probably is the control valve it is in the bottom of the three point pump. If I can be of further help Email me
