MF TO32 23C Diesel
GregB
10-23-2004 19:03:28
I have a TO35 with a 23c Diesel.
The second and fourth injector line is leaking at the injector. The nut will not tighten any more. It is a steady drip. I was told the the flair is cracked on the injector line casuing this problem. The MF dealer in my area tells me they
do not carry parts for this model any more and will give me no help. Does anyone know where I can obtain new lines or good used ones.
Thomas
10-25-2004 13:04:16
 Re: MF TO32 23C Diesel in reply to GregB, 10-23-2004 19:03:28
If it's leaking from the flare, cut a small piece of sheet lead, to fit inside the union, with a hole drilled in the middle for fuel flow. Tighten this onto the injector and you should have a good seal. This is an old trick used many times on Leyland engines which seem prone to pitting on the ends of the pipes.
However, if it's anything like my FE35 with the same engine, the leak of pipes are always cracking because the fuel tank is mounted on rubbers, the vibration of the tractor causes the pipe to flex and crack. I've given up repairing it, just accept a bit of a drip.
