Thanks for the information, Will. I made my first attempt at transmission maintenance today by draining the fluid from my Ferguson teo20(?). The stuff was dirty, I knew, because the pump would hardly work. I had parked the tractor in the barn, so I slid a triangular drip pan under it admidships and removed a likely-looking bolt. Wow! Did that stuff ever come out! I got the gush stopped before the pan overflowed, but barely. Into a nearby 5 gallon pail it went. And again. It slowed down to a trickle after two pansful, so I left it to drip for a while (remembering advice on another posting) and came back after an hour to an overflowing pan and a puddle. Right. Drained the pan, put in the plug, and decided to try the big one towards the stern. Opened it with a pipe wrench. Holy Smoke! What a gusher! I got the plug back in -- tricky threads, those -- before the flood. Drained the pan again. Pail getting full. The gusher died out quickly after that and I capped it after completely filling the 5 gallon pail. Interesting substance, that. Sorta greenish brown, with a bit of carmel in it. Lumpy, at times. The plug had gray sludge in it. Then I went to Canadian Tire to locate appropriate oil to replace the gunk. I hit upon the only obvious one, GL4 hydraulic fluid for tractors and trucks with tranny and hydraulics together. On special at 26.14 for 20 litres. I hope this is the right stuff. (Please let me know if it isn't before I put it in.) I assume that it gets poured down through the plug next to the gearshift. I noticed that CTC has 80W90 gear oil, but a post here warned against the high detergent level in it for Fergusons. If this goes well, I assume that I'd better do the same thing with the MF 35, as well as changing the engine oil. Local word is that the MF 35 is very hard to start in winter. Isn't 15W40 pretty thick? I've always used regular #10 in tractors in winter. My dad's 414 diesel took 10W, and even then it was very hard to start. Oh yeah, the International had a glow plug activated by a little lever and you could tell when it was hot enough by touching the instrument panel in just the right place. Does the 35 have a glow plug? Any chance the pre-heater is activated by turning the key backwards before firing the starter by turning to the right? If you have hung in this long, thanks. Advice will be appreciated. Rod
