mf 275 265
tony birling
10-21-2004 01:03:37
On my 275 the front axel pivot bushing is out. How big a job do I have ahead of me in replacing it. I looks like I'll have to take the whole front end off to change it.
Also My 265 makes an occasional grinding noise somewhere in the vicinity of the clutch housing. (8 speed tranny-2 stage clutch)When I step on the clutch part way it still makes the noise but when I step on the clutch all the way it stops. What's wrong? Throw out bearing maybe? Is it a big job to change it? Is something else wrong? Or would I be better off going to a dealer for this repair?
Big Dean
10-21-2004 16:45:18
 Re: mf 275 265 in reply to tony birling, 10-21-2004 01:03:37
The front axle center pivot pin bushings can sometimes be changed with out removing the front if the pin is not rusted in. If it is you may have to remove the front end and strip it down so you can get the front axle support in a press to remove the pin. The noise on your MF265 sure sounds like a bad release bearing if it is you will have to split the tractor between the engine & the transmission. this is not a bad job if you have to equipment to do it with. If I can be of help on any of it Email me
