3 point hitch capacity
paul bush
10-18-2004 14:39:03
Can my 1975 MF135 handle a 6' box blade? Anyone know the hitch weight capacity?
Thanks
CH
10-20-2004 18:57:00
 Re: 3 point hitch capacity in reply to paul bush, 10-18-2004 14:39:03
135 and 245 should be close. Brian Mabie from Mabie Bro's, a good authority answered my question following.
Hello, Could you tell me the lift capacity of a '81 MF 245 diesel? Thanks,
Charlie
3100lbs
Jerry/MT
10-20-2004 17:46:47
I seem to recall some comments in the past for TO-30's where certain individuals had tested them with weights and said that 750 lbs was about max for that tractor. Another individual said 800 lbs. I believe that their are two limiting factors:1)the relief valve setting in the hydraulic system, and 2) the tipping moment due to the location of the center of gravity of the lifted object. Try an archive search and see if you can find a weight limit for a MF 135.
Cosmo
10-18-2004 17:24:27
I don't know the weight of the 6' blade, but it will handle that and a whole lot more. If you're asking about the width, it'll handle that too. Regards, Cosmo
Ray,IN
10-18-2004 21:33:21
 Re: 3 point hitch capacity in reply to Cosmo, 10-18-2004 17:24:27
I use a 6' yard box with my TO30 and get along fine. My MF135 will of course do much better with the box blade: more HP and weight=better results.
