Mf 65
julius
04-07-2000 19:04:41
Just trying out a 1958 65 runs great been in the weeds 2 or 3 years. i has wondering the hp, the three point hitch wont go back down only if you push in clutch and last the high low range shifter moves very easy and will pop out any info will be helpfull thanks julius
ps whats it forth ?
Bob of Virginia
04-08-2000 09:01:39
 Re: mf 65 in reply to julius, 04-07-2000 19:04:41
HP about 50 depending what engine. Check fluid level of trans; if low bring up until you have a reading on the stick. Then run it for 30 minutes or so and check for leaks, most notedly under the belly around the cluch inspection plate. A leak here means spliting the tractor; this from very recent experience. Goood luck.
julius
04-08-2000 23:12:43
 Re: Re: mf 65 in reply to Bob of Virginia, 04-08-2000 09:01:39
the engine is a cont. g176
thanks bob of virgina
