Steering Control valve
Franklin Scott
10-17-2004 15:30:44
Do any of the newer MF's utilize a rotary valve for steering control as were used on some Ford, AC and IH tractors???? Just wodnering as I woudl like to find one of these valves for a project...
Thomas
10-19-2004 12:36:06
 Re: Steering Control valve in reply to Franklin Scott, 10-17-2004 15:30:44
I assume that you mean a steering orbitrol. I know that certainly all 500, 600, some 200, 300 4200 and 4300 series use a standard Danfoss unit, you need to find the right size unit both in terms of pump flow rate required and output flow per rev. As far as I'm aware MF didn't fit a priority valve to the orbitrol. You can buy cheaper units built under licence from a Turkish manufacturer, you need to find your importer, can't help as I'm in UK.
