Massey 230 diesel leak-off
Rascal63
10-16-2004 19:48:32
I have fuel leaking from the leak-off line at the #3 connection. I have checked it and the banjo bolt is tight. Any Ideas?
Big Dean
10-17-2004 14:19:37
 Re: Massey 230 diesel leak-off in reply to Rascal63, 10-16-2004 19:48:32
Unless the line is cracked where it connects to the banjo fitting you need to replace sealing washer one on top and one on the bottom of the banjo fitting you need to get enough of the washer yo replace all of them you will have to loosen all the bolts from all three of the injectors to replace them. I prefer to use the aluminum washer from Massey rather than the copper on after market ones.
