shuttle for massey 35 /202
greg m
10-15-2004 18:53:29
Can you put a hydrostatic trans from a 35 into a 35 with a clutch setup. i.e. can I just remove the center section and swap or is the more than that...
Big Dean
10-16-2004 07:50:47
 Re: shuttle for massey 35 /202 in reply to greg m, 10-15-2004 18:53:29
You can install a the reverseomatic or later called an Instant reverse transmission in place of the transmission normally used in the MF35 you have to have the flywheel for the instant reverse transmission you have to set the distances the torque converter sets from the engine with shims each tractor is different. If I can answer any more question about this Email me.
