35 diesel not charging
ric
10-15-2004 12:11:52
my 35 is not charging where should i start looking first to fix this
Thomas
10-18-2004 12:59:58
 Re: 35 diesel not charging in reply to ric, 10-15-2004 12:11:52
Try overriding the control box by making a temporary link from the -ve battery terminal (assuming +ve earth, use +ve if not) to the dynamo's small terminal. Measure battery voltage at full revs before and after. If you notice significant improvement then change the control box, they're cheap new and very dificult to set up an old one. Don't leave this link in for long as you'll cook the battery.
If this doesn't help get the dynamo off, connect the two terminals to power and the casing to earth. If the dynamo spins like a motor then it's probably OK, so just replace all the wiring as it's too much hastle trying to identify a dodgy wire section, and if one bit's gone another's probably going. If the dynamo won't spin get it reconditioned.
Rod in S.F. Ontario, Cana
10-24-2004 14:19:46
 Re: 35 diesel not charging in reply to Thomas, 10-18-2004 12:59:58
Thomas:
I gather from the previous posting that some of these tractors had a positive ground. My recent purchase seems to charge normally, but it reads on the negative side of the gauge. This sounds to me as though it has been switched to a negative ground from a positive, possibly when upgrading to 12v.
Anything to that?
Thanks,
Rod
