pto
gary bar
10-15-2004 09:37:00
Thanks for all the advice. but do i understand right all i have to do is lossen the bolts and slide the shaft out, aren't there gears that have to be aligned ? should i mark the flange before i remove it ? am i making this harder than it is ? Thanks Gary
Big Dean
10-15-2004 15:53:43
 Re: pto in reply to gary bar, 10-15-2004 09:37:00
Before you start place the pto lever in ground speed this will keep engine speed coupler with the ground speed gear on it from dropping in the rear case when you pull the shaft out. Some people head the front down hill but the front has to be down quite a bit to keep the oil from running out. I always preferred to drain them at the back plug. Remove three bolts holding the plate that keep the bearing and seal retainer in. That retainer has a large O-ring that seals the outside of it you usually have to stick something through the hole in the shaft to pry it back enough to get the O-ring clear from the case. I have a picture with details on how to replace the pto seal. I can email it to you if you would like.
