MF 65 Diesel Injection Pump leaking...
Mike Burdick
10-14-2004 20:46:39
I have a MF 65 Diesel and the injection pump is lightly leaking between the round part and the square shape above it. I can't find any bolts to tighten it and it clearly has a gasket between them.
Does anyone have any suggestions as how to fix this?
Thanks in advance...
Mike
Tommy D6-8U
10-15-2004 16:58:25
 Re: MF 65 Diesel Injection Pump leaking... in reply to Mike Burdick, 10-14-2004 20:46:39
Mike,
Haven't been on the board much lately. How did your rebuild turn out? If you have leaks from the injection pump now, at least it's running, right? (SMILE)
Tommy
Big Dean
10-15-2004 16:52:55
There are two small nuts that stick up from the top one on each side about mid way from the ends. I doubt tightening them will stop your leak it usually does not. When tightening them you have to be careful they are tiny bolts and very easy to twist off. It is not real hard to change those gaskets but there are some things you should know before removing the top it has a spring in the top that has to be hooked back in the same holes it comes from on both ends. You also have to be careful not to stretch the spring out of shape. I have a drawing that shows all of this on my repair CD disc.I can email the drawing to you if you would like
Mike Burdick
10-15-2004 19:06:36
 Re: MF 65 Diesel Injection Pump leaking... in reply to Big Dean , 10-15-2004 16:52:55
Tommy,
The rebuild went fine - other than some of these nasty leaks. (Smile) It's kind of funny how the rebuild turned into fixing the power steering, the clutch, the lift hydraulics... My water pump started leaking badly because the shaft seal was worn. I couldn�t find a replacement pump so I machined a new impeller for the old one such that the hub was a little larger to accommodate a pocket so I could press fit a ceramic seal face. This seems like a better alteration than the original seal to cast iron hub. I�ve been watching the temperature closely and so far no problems. This will also make the pump completely fixable in the future since all the parts are now common items. The new shaft seal cost around $12.00 and the impeller was about 1 hour on the lathe and mill. By the way if others have a problem with their pump, a �PAC-Seal� by Flowserve is an exact replacement and can be had at most pump suppliers as a stock item.
Tommy, I could never have done it without your help as well as others on this board. Thanks ever so much!!!
Dean,
If you want to email a drawing to me that would be great. My email address should be listed with this post.
Dean, if we're talking about the same bolts - mine have a wire, which crosses between the two for holding. Are these the bolts you mentioned?
Thanks...Mike
Mike Burdick
10-16-2004 09:32:45
 Re: MF 65 Diesel Injection Pump leaking... in reply to Mike Burdick, 10-15-2004 19:06:36
Dean,
Thanks for the information! Do you know if the gasket between the top and body gasket is available or does it have to be made from gasket stock?
Mike
