MF 135
DonaldinKy
10-14-2004 16:21:47
I just brought a MF 135 and wondering what oil to used in the motor. I have not got a chance to get a Manual for this tractor yet. What size plow and Disk will this tractor pull. Thanks Donald
ChrisK
10-18-2004 00:30:32
 Re: MF 135 in reply to DonaldinKy, 10-14-2004 16:21:47
Hi DonaldinKy,
congratulations to such a great tractor.
I used to work with it in Germany.
Oil here that we used was type SAE15-W30 for example. But it depends a little on your temperature, weather condition.
Which plow...I would say 20 PS per plowshare.
If you have a small plowshare then 2 should be no problem since you have 33 or 35 horsepower.
I wonder where I can get a nice poster of an MF35.
User Manual you can easily find on www.ebay.com or www.ebay.de or other ebays in the world.
Greetings from Germany.
Indydirtfarmer
10-15-2004 04:01:16
What part of Kentucky are you from? I live just south of Louisville. (The "Indy" part of the screen-name refers to our farm in Indiana) Some of the state has "easy plowing" ground. Other parts are like rock. That makes some difference when it comes to a plow. If you're near Louisville, I have a good parts/service source for you and your Massey. If you're interested, e-mail me at [email protected] I'm at work now, but I'll get back with you later this evening. John
Indydirtfarmer
10-14-2004 19:24:40
You got yourself the best small utility tractor EVER made. To this day, no one has ever built anything any better.
You should be able to handle 2 x 14" plow, but a 2x12" will handle easier.
That tractor will pull an 8 disk, but if you're planning on using a 3 point disk, the WEIGHT will be the determining factor. A 6' or 7' would be about the limit.
And about the oil. There's 10,000 theories on what's best. I run 15/40 in everything nowdays. So does the aoto mechanic we use, AND the tractor/combine mechanic I do business with. Good oil...One size fits all. John
CH
10-17-2004 17:50:36
 Re: MF 135 in reply to Indydirtfarmer, 10-14-2004 19:24:40
Except the 245.
Gerald J.
10-14-2004 20:26:59
I use 10W30 or 10W40 in my MF-135. Modern oils are better than the none detergent straight weights of old and cut way back on crud and corrosion.
I've plowed for years with 2x16 in central Iowa. Generally 4 to 5 mph.
I made a 6' disk out of half of a 12' Oliver disk and it pulls as hard as the plow if I let it go into the ground. Its a pull behind with its own wheels set by hydraulic cylinder. Its not handy for getting into a garden next to the fence, but its heavy enough to penetrate when needed. Most 3 point disks are too light to do real work.
Gerald J.
