MF65 -3pt. troubles
Tom in Wis.
10-13-2004 14:12:56
To have any control with my draft lever I have to lock my left hyrolic lever in the rearward postion. This seems to to force fluid through the valve. After a couple of hours of plowing my fluid gets to hot to pump. I have read my manual several times and it doesn't mention locking the lever back to control the 3pt. Thanks for any advice, Tom
Jack in NB
10-13-2004 15:42:34
 Re: MF65 -3pt. troubles in reply to Tom in Wis., 10-13-2004 14:12:56
Hi Tom -
You have the correct combination. We have 4 equipped with 2 lever valves. On all of them the left lever acts as a switch valve - center position activates the right lever for remote operation; back is normal three point.
Forward dumps the 3-point. Some folks use the left lever for three point control (back raises, center stops, forward lowers), but you lose the benefit of the position control.
Not sure why the oil should get so hot though.
Jack
