Model Ferguson To dies out when pulling equipment
jay vickrey
05-21-1998 18:36:56
can anyone tell me why my tractor keeps dying
out when I pull equipment. It will run appro. 2-3 minutes then will start to die out The tractor runs fine when it idles. I have been told it could be the govener. Any feedback would be appreciated.
Steve Wolfe
05-23-1998 06:16:02
 Re: Model Ferguson To dies out when pulling equipment in reply to jay vickrey, 05-21-1998 18:36:56
I experienced the same problem with my TO-35 after reviving it from a "10yr sleep". You didnt mention which TO you have or what carb. you are dealing with. The first thing I would do if it is a Marvel-Schebler or similar carb., is to check the "power jet" needle valve adjusting screw. Should be about 1 3/8 turn open.
My problem turned out to be the fuel strainer that goes up into the tank. The easy way to check this is to remove the sediment bowl and open the fuel cut-off valve and see if your getting a good steady flow. If it seems restricted you will have to remove the fuel from the tank or stand the tank on end to remove the complete valve/bowl assembly to get to the tank stainer. It is a series of little disks threaded into the valve body. Simply unscrew them until the disks are loose and blow or wire brush the dirt or old gunk.
Depending on which carb. you have, there maybe a screen just inside the fuel connection to the top of the carb. If you have a Marvel-Schebler carb. you can remove the drain plug at the bottom and see if your getting a good flow.
If everthing checks out ok, it maybe time for a carb. rebuild. The M-S carbs are very easy to rebuild.If your problem is in the carb., I would suspect a the "power" needle valve passages may be blocked.
I would mess with the governor until your sure that the carb and ignition are ok.
You can, how ever, check the governor operation by following the manual procedures. If you dont have manual, let me know and I'll fax you those pages.
Good luck, Steve
chris
05-26-1998 22:44:29
 Re: Re: Model Ferguson To dies out when pulling equipment in reply to Steve Wolfe, 05-23-1998 06:16:02
: I experienced the same problem with my TO-35 after reviving it from a "10yr sleep". : You didnt mention which TO you have or what carb. you are dealing with. The first thing I would do if it is a Marvel-Schebler or similar carb., is to check the "power jet" needle valve adjusting screw. Should be about 1 3/8 turn open.
: My problem turned out to be the fuel strainer that goes up into the tank. The easy way to check this is to remove the sediment bowl and open the fuel cut-off valve and see if your getting a good steady flow. If it seems restricted you will have to remove the fuel from the tank or stand the tank on end to remove the complete valve/bowl assembly to get to the tank stainer. It is a series of little disks threaded into the valve body. Simply unscrew them until the disks are loose and blow or wire brush the dirt or old gunk.
: Depending on which carb. you have, there maybe a screen just inside the fuel connection to the top of the carb. If you have a Marvel-Schebler carb. you can remove the drain plug at the bottom and see if your getting a good flow.
: If everthing checks out ok, it maybe time for a carb. rebuild. The M-S carbs are very easy to rebuild.If your problem is in the carb., I would suspect a the "power" needle valve passages may be blocked.
: I would mess with the governor until your sure that the carb and ignition are ok.
: You can, how ever, check the governor operation by following the manual procedures. If you dont have manual, let me know and I'll fax you those pages.
: Good luck, Steve
Jack in NB
05-23-1998 03:11:08
two basic checks - fire and fuel.
Jay -
When it quits, have you got at least 1/4" of fire
at each spark plug? If you do, the ignition system
probably isn't the cause.
For a fuel check - does the choke make a difference?
If it does, there may be a restriction in fuel getting from the tank to the carb, or dirt in the carb.
If the carb has a drain plug, remove it after it quits, or remove the fuel line at the carb and check for a steady flow of fuel to half-fill a cup.
CAUTION: Make sure that raw fuel doesn't spill onto the hot exhaust, if you have the low exhaust system,
or stalling out may no longer be a problem!!!
