MF 165 gas fuel tank pressure
cs Kent
10-08-2004 04:26:29
I have the perkins 212 gas, it has a replacement fuel cap, I don"t think its the right one. The cap has a sticker on it " remove slowly fuel may be under pressure..." My fuel gauge does not work, I ran it for about 4 hours shut it off and waited 10 minutes. Then slowly removed the cap and took a gas bath. I could not beleive how much pressure was on the tank. What cap should be used here? Is this normal to have the fuel system under this much pressure? I have had this tractor for 5 years, but never had a need to refuel under this circumstance. Thanks
Leland
10-10-2004 00:35:43
 Re: MF 165 gas fuel tank pressure in reply to cs Kent, 10-08-2004 04:26:29
I've got hundreds of hours on one and thats common tank right on top of engine a lot of heat gets absorbed I started leaving cap a little loose bacause new caps helped for only a short time.
mowr
10-08-2004 18:05:22
Be thankful it didn't blow a fuel line (or the tank) and spray gas on the hot engine, distributor and you! As far as I know, all tractors require vented fuel caps.
txblu
10-08-2004 06:49:08
Don't know of one that is not vented.....for the obvious reason, plus on gas it tends to overpower the float shut off valve (needle) and cause flooding and rich mixture running.
Mark
