MF245 deisel popping back thru air cleaner
mocc
10-07-2004 20:42:29
The tractor starts fine but when running it constantly makes a loud popping noise out the air cleaner. Think it might be the valves?
Could it be anything else?
Thanks for the help,
Paul
Big Dean
10-08-2004 08:36:18
 Re: MF245 deisel popping back thru air cleaner in reply to mocc, 10-07-2004 20:42:29
That problem is usually caused by either a broke intake valve spring or a bent or broke rocker arm. It can also be caused by a blown head gasket between the cylinder or a burned intake valve. Loose the injector lines one at a time till it stops popping to fine which cylinder it is causing the problem.
txblu
10-08-2004 06:53:05
Let's explore this. Popping is pressure introduced into the air inlet to the engine. What's there? Intake valve. What's the purpose of that? Open up at the right time to allow fuel air mixture into the combustion chamber and close at the right time so that the mixture can explode (in the cylinder) and stay closed while the results of the pressure impulse are pushed out the exhaust port.
Sounds like it taint doin it's job.
Mark
gas
10-10-2004 06:49:02
 Re: MF245 deisel popping back thru air cleaner in reply to txblu, 10-08-2004 06:53:05
Mark, doesn't that Perkins have an injector direct to the combustion chamber so all that goes through the intake valve is air??*?
txblu
10-12-2004 07:34:05
 Re: MF245 deisel popping back thru air cleaner in reply to gas , 10-10-2004 06:49:02
No, it has an indirect injection which is a pre-combustion chamber. Must be why it makes that unique noise when running and it starts easily when cold.
Mark
txblu
10-12-2004 07:38:38
 Re: MF245 deisel popping back thru air cleaner in reply to txblu, 10-12-2004 07:34:05
gas,
Correction time. I reread the initial post and it did say Diesel. You are correct. My Diesel AD3/152 has indirect injection, as I just replied, but as YOU stated, the intake only sees air (if the valve is closed, i.e.functioning properly). If not, it sees the "diesel fuel-air" mixture back from the combustion chamber.
Mark
gas
10-13-2004 13:01:29
 Re: MF245 deisel popping back thru air cleaner in reply to txblu, 10-12-2004 07:38:38
Thanks, Mark! I didn't know for sure either.
