MF 1155 turbo
Joel (Mi)
10-05-2004 13:54:08
We have a 1155 with a M&W turbo on it. Parts of the exaust system have rusted out especially the piece that connects the two manifold pipes to the bottem of the turbo.
Does any one know if there are still parts for the M&W turbos? The worst part has a M&W casting number on it so it is not a MF part.
Would pull the turbo because its kind of small but think the fuel pump is turned up. We are also trying to sell the tractor right now.
Thanks
Joel
mark steinmann
10-17-2005 00:24:20
 Re: MF 1155 turbo in reply to Joel (Mi), 10-05-2004 13:54:08
do you still have the 1155 whats the condition and price where are you located
Dold
10-09-2004 15:18:02
Joel
I don"t really know what the parts availability is, however I have installed several M&W turbos on 1155s. One particular 1155 I installed a M&W turbo when the tractor had 6500 hours. The customer ran it to over 11,000 hours then overhauled the engine. That waas 10 years ago. To my knowledge that tractor is still running. At one time we had it running at 220 hp. at 2,000 rpms (factory rated at 140 hp). We did put 2805 injection nozzles tips in it other than the turbo the engine was stock. When he later bought a 300 hp Versatile 4Wd we turned the fuel back to run about 190hp. Where it runs today. Some of the last 860 Massey combines (1981)had a 540 Perkins engine that were equipped with a factory turbo. I would keep it unless you don"t need or want the horsepower.
Tom Dold Implement Co.
Howard, SD 57349
[email protected]
megamoodairy
10-05-2004 20:14:14
Pull the turbo and get your injection pump reset. Perkins typically would beef up any factory turbo charged engine like what comes on the 1135. The 1155 is naturaly aspirated from the factory so the crank, valves and pistons arn't built to handle a turbo in the long haul. I would change it or unload it. Also as far as I know there is very limited M&W parts availability.
