M-H 44 Special -battery cables
Ken In Ontario
10-03-2004 17:52:41
Thanks in advance for any assistance. Am restoring M-H 44 Special. I have heard from some sources not to use regular 12V battery cables.
If this is true, what should I be using for:
The cable from the starter switch to the starter motor?
The cable from the battery positive to ground?
Bruce C.
10-03-2004 19:05:57
 Re: M-H 44 Special -battery cables in reply to Ken In Ontario, 10-03-2004 17:52:41
Use the same size cables as were on the six volt system.The size is 0 if I recall correctly.The cable is the same size from the battery to starter button and from starter button to starter.The larger the cable is more the power you will get from battery to starter.
