44 massey starting problem
Willie Sawrenko
10-02-2004 23:31:05
My 44 massey 4cyl gas 6 volt system will not crank over continuous,but has to be bumped over to start.I discovered that it has diesel pistons,I'm not sure why.I was told that they have a 12 volt starter,and by directly jumping the starter with a 12 volt battery it turns over great.I would like someone to tell me why the 6v system won't do the job.All cables and starter switch as well as battery are new.I would like to keep it original if I could.Were the diesel tractors 12volt?.Why does this gas tractor have diesel pistons?
ACWC
10-03-2004 15:55:07
 Re: 44 massey starting problem in reply to Willie Sawrenko, 10-02-2004 23:31:05
I had a 44 with diesel pistons and it cranked real slow with 6 volt. So I had the gen changed to 12v and put a 12v coil changed everything to neg ground and started great from then on. left the starter 6v and it was fine.
marlowe
10-03-2004 10:34:16
6v will do the job!your battery might be week, what size cables? should be 0 size not some junk from walmart. is every thing clean at ALL conections. or your starter is going bad. 12 volt will NOT fix poor mantince
