hh-100 techusmeh engine for mf-10 garden tractor
hank from ny
10-01-2004 20:19:17
Need engie for rebuild. I blew the rod, crank and piston.
Gerald J.
10-02-2004 08:22:15
 Re: hh-100 techusmeh engine for mf-10 garden tract in reply to hank from ny, 10-01-2004 20:19:17
I needed piston, rod, and rings for the HH-100 Techumseh in my JD 112. JD quoted $179. My block needs a lot of boring to fit a round piston. For under $300 I dropped in a 10 HP Briggs (without electric start) and the tractor mows on 1/3 the fuel. The shaft on that particular Briggs was half an inch higher above the deck and a bit smaller so I had to lengthen the mower belts, make a pulley spacing sleeve, and adjust the drive clutch. I had to drill a couple new mounting holes.
Gerald J.
