clutch wont dis-engage pto
Mikey RT
09-29-2004 15:11:58
Has any body run into this problem,mf135 with loader. pto rarely used ,tractor used mainly for loading round bales,when you step on clutch pto keeps on turning,is there any adjustments or is clutch bad, goes into gear and takes off fine! Thanks Mike
Kevin Bismark
10-01-2004 17:53:08
 Re: clutch wont dis-engage pto in reply to Mikey RT, 09-29-2004 15:11:58
I thought that little one had live power, think a neighbor had one, thought it had live power at least.
Ray,IN
09-29-2004 20:33:44
This is the way Big Dean's website describes it:
The 2nd stage clutch is adjusted from the bottom. Remove the dust cover and you will see 3 square head bolts(1/4-28 I think) equally spaced 120* apart with a lock nut on each. First, adjust the clutch pedal to obtain 3/4" free play between the clutch arm and where it hits at rest. Now adjust the 3 bolts to 0.050" clearance. If the PTO clutch still does not disengage the PTO shaft, there are two more things to consider. First is perhaps this clutch is frozen. Second, if the clutch assembly has been apart and some parts replaced the PTO clutch usually will not disengage because of mismatched parts. MF used two different suppliers and the parts are not enterchangable most times. The clutch should be replaced as an entire assembly
MikeyRT
10-01-2004 18:44:15
 Re: clutch wont dis-engage pto in reply to Ray,IN, 09-29-2004 20:33:44
Thanks Ray, I adjusted clutch like you said and it works like a new one,disengages pto about half way down or so. Thanks again Ray, Mike ps This is a great web Site!
Ray,IN
10-02-2004 20:48:06
 Re: clutch wont dis-engage pto in reply to MikeyRT, 10-01-2004 18:44:15
I can't accept the credit for the advice. I read about this on Big Dean's website(he is a regular contributor to this board) and just passed it along. Visit his website whenever you have a question; he very likely has written about it and suggested a solution.
