mf 35 diesel not charging battery
ric
09-23-2004 17:39:22
where should i start first in trying to correct this problem
ric
09-27-2004 18:00:44
 Re: mf 35 diesel not charging battery in reply to ric, 09-23-2004 17:39:22
thanks guys
Thomas
09-24-2004 14:39:39
You can check the dynamo by earthing the case and connecting the two terminals to feed. If the dynamo spins then it is likely to be OK. Obviously don't do this with the fan belt attached, it's not designed to be a motor. Don't bother trying to set up the regulator, throw it away and buy a new one. They are very cheap and it is not easy to set them up.
Mike(Sweden)
09-24-2004 01:15:29
Check the generator(brushes).
