MF 35 CRACKED ENGINE BLOCK
KS
09-23-2004 14:21:06
CAN BLOCK BE WELDED TO REPAIR LEAK?
parts man
09-23-2004 16:00:33
 Re: MF 35 CRACKED ENGINE BLOCK in reply to KS, 09-23-2004 14:21:06
What is the engine, gas or diesel, where is the leak. Need a little more info!
KS
09-24-2004 06:33:37
 Re: MF 35 CRACKED ENGINE BLOCK in reply to parts man, 09-23-2004 16:00:33
THANK YOU FOR YOUR REPLY. THE ENGINE IS A DIESEL,THE CRACK IS ABOUT 3 INCHES LONG ON THE SIDE OF THE ENGINE BLOCK. THE ENGINE RUNS GOOD.IF THIS IS A REPEAT MESSAGE, PLEASE FORGIVE ME, HAVING COMPUTER PROBLEMS. THANK YOU
smokey
09-24-2004 16:57:19
 Re: MF 35 CRACKED ENGINE BLOCK in reply to KS, 09-24-2004 06:33:37
If this block is from a A3-152 Perkins then getting another block or motor should not be that difficult as they are very common - at least in Australia - I have a spare in my shed
Thomas
09-24-2004 14:43:19
It can be done, it's a complex procedure which I've only ever read about. They cut a square in the block and a plate to fit. Then holes are drilled half in the block and half in the plate, and dowells are fitted. I know it can be done on the vehicle, perhaps try an engine reconditioner?
Brent
09-24-2004 16:51:59
 Re: MF 35 CRACKED ENGINE BLOCK in reply to Thomas, 09-24-2004 14:43:19
What about some sort of epoxy, there is some really good choices out there. J.B. weld or check with an industrial supply house. I know that you have to have a very clean surface for this to work.
