smoken MF255
Mike S. in Ont.
09-21-2004 06:26:42
My MF 255 with the perk 236 seems to smoke excessively. It seems to run good and uses hardly any oil. I have cleaned the outer filter and changed the inner filter, and added diesel fuel additive but it didn't seem to help. Any help would be appreciated. Mike S.
Big Dean
09-22-2004 11:48:29
 Re: smoken MF255 in reply to Mike S. in Ont., 09-21-2004 06:26:42
If the Smoke is black check the air cleaner hose to be sure it is not resticted. Dirt dobbers love to build their nest in the air system on them. Also make sure the hose is not sucking together. I have seen that a few times. If I can be of further help Email me
Roy in UK
09-21-2004 13:22:00
Another thing to check. The condition of the air filter.
Rick (ont)
09-21-2004 13:08:20
My 35 with the perkins diesel was doing the same thing. Big Dean recomended a quart of transmission fluid in the fuel with a full tank of fuel and run it all through. It cured the smoke after a few hours of running. I add a quart once a year now to keep things clean.
holm
09-21-2004 08:51:22
You should have the injectors checked to make sure they are working properly.
