MF135
JERRY in Alaba
09-20-2004 19:34:33
I am buying a 1972 MF135 WITH 2300 HOURS from a person I know who has had it for 15 years. It seems in good mechanical shape with good tires I am paying $3500 for tractor and 5 ft. bush hog is this a fair price. on the right side directly across from the PTO lever is pointer with notches the pointer moves from one notch to another . What is this ?
ben uk
09-23-2004 13:08:36
 Re: MF135 in reply to JERRY in Alabama, 09-20-2004 19:34:33
Also if its spent those 2300 hours on a loader, you may have some issues.
Im preety sure mines had a loader on it at some point, the front axle is knackered, the clutch and brake pedals have almost no tread left on them, and the steering arms are bent.
Still does the job, and runs like a pro though.
As Txblu said, good care will make up for a lot of hours.
txblu
09-21-2004 06:53:38
Before you take too much stock in the hour meter, you might look at other things. If it is truly 2500, the brake pedals will only have slight wear and the steering will be tight....two of the best ways I know of determing true hours. The meter can be run back, and once thru 10,000 hours it starts over.
I have (had) one I bought with 2500 hrs on it and another with 6000. I believe the 6000 which had slight wear. The one with 2500 had much more wear than the 6000 telling me that the hour meter rolled at least once, cause there was too much wear to just be rolled back. I find that diesels are usually more worn out for a given year/model than gas. My estimation of that is that people who work their tractors must have the best efficiency. Gas versions are used for light duty where fuel consumption is not a major issue (my opinion, based on acquired facts).
Course hours mean nothing as compared to proper care.
Ray,IN
09-20-2004 21:56:03
These tractors are in demand, and usually sell for around $5,000 in good condition around SW Indiana. If you're asking about the small lever on the right side opposite the PTO lever, it's to regulate the response of the hyd system to uneven ground. When plowing this helps maintain the same depth over uneven ground when properly adjusted.
