massey's continental differences
cookie monster
09-20-2004 16:59:15
what are the differences between a f140 and a f162
I see that bore and stroke are the same ? are they the same h.p .will a f162 fit where a f140 sat?
Blake B
09-20-2004 19:17:06
 Re: massey's continental differences in reply to cookie monster, 09-20-2004 16:59:15
Will the sleeves for a 162 fit in a 140 block?
Alberta Mike
09-21-2004 05:46:28
 Re: massey's continental differences in reply to Blake B, 09-20-2004 19:17:06
Most of that series of engines (all three sizes were called the F400 block series) were sleeveless. I know some of the 124's had sleeves (like on my Case model V) but at the same time (1940) my Massey Harris 101 Junior had a sleeveless 124 engine.
Bruce Colbourne
09-20-2004 17:50:50
The continental 124,140 and 162 all use the same block.The bore of the engine was increased to give you the bigger displacement
cookie monster
09-20-2004 17:55:35
 Re: massey's continental differences in reply to Bruce Colbourne, 09-20-2004 17:50:50
Ive also found what looks to be a f145 as well as a f163 and these blocks look the same also. a bit confused but learninging thank you all
Alberta Mike
09-20-2004 17:11:38
The stroke yes, but not the bore. That's why they are different displacements (124, 140, or 162 cubic inches due to different bores). Any will bolt up or to wherever the other was no problem. I've done it a few times myself.
Dr. Chris
09-20-2004 17:03:48
I always thought that those 2 engines used the same block, different pistons. So, I say yes it will fit. I could be wrong though.
