massey 44 12volt or 6
cummins power
09-20-2004 14:17:08
I bought a massey harris 44 in rough condition and Im about to start restoring it but I have always been use to the green stuff and Im not for sure if it is a 12 volt or 6. Also it has a ford generator on it is that ornigal or not. Also Im considering on making it a pull tractor and ideas or suggestions
thanks
Bruce Colbourne
09-20-2004 15:07:52
 Re: massey 44 12volt or 6 in reply to cummins power , 09-20-2004 14:17:08
The massey 44 was built with a six volt positive ground system from the factory.The original generator would be a autolite unit.If there is anything else I can help you with drop me a line
willie
10-03-2004 22:10:20
 Re: massey 44 12volt or 6 in reply to Bruce Colbourne, 09-20-2004 15:07:52
Hi Bruce I noticed your reply to 'Massey 44 12v or 6v'. The 44 massey I recently purchased is a 6v system and is connected negative ground.Would this be the reason for my cranking problem?.Could I just reverse the cables without causing a problem and hopefully solve it?
