MF35 Lift question
mikeb
09-19-2004 13:13:43
When using a 5' box blade, my lift only takes it up about a foot off the ground. It will hold it there fine, except when I press in the clutch pedal, and then it will lower to the ground. Take my foot off clutch, and it will raise back up again to that same height. Also will go to ground when I shut tractor off. Takes only a few seconds to lower to the ground either way. Any sugg? Thanks, Mike
txblu
09-20-2004 05:48:01
 Re: MF35 Lift question in reply to mikeb, 09-19-2004 13:13:43
The PTO clutch runs the pump too, unlike Ford, at least on MF35 with live PTO. So if you shut off the PTO, via the clutch all the way down, the pump stops. Hence you are at the mercy of your lift cylinder rings. If worn, it will leak down. Mine does, but not so bad as to warrant a teardown. Holds just fine when pump is running. Heavier oil, as mentioned, will reduce the rate of decent.
Mark
Chris C.
09-19-2004 15:42:00
The clutch thing is normal operation. do you have a dual clutch? As far as the implement dropping after shut down, the time seems to vary on condition of lift piston, lift piston rings, etc. my 35 takes about 3 minutes to creep down with a 6' roll-over box scrape and thats with new lift piston rings.
mikeb
09-19-2004 19:25:33
 Re: MF35 Lift question in reply to Chris C., 09-19-2004 15:42:00
No, I think it is just single...rev,1,2,and 3rd..hi and low gear. So the box blade should not go any higher than say 1 foot above ground? It will drop in about 3-5 seconds. It just seems that when you put the clutch in the blade should not drop like that, but as this is my first tractor maybe I dont know for sure...Thanks
sibby(Aus)
09-19-2004 23:59:19
 Re: MF35 Lift question in reply to mikeb, 09-19-2004 19:25:33
could be your stand pipe o,rings, remove the rectangular plate under the seat on front r/h side on top of lift cover, replace o,rings and back up washers and locate pipe into top of hyd pump and retry. easiest thing to try first. cheers.
Michael(Sweden)
09-20-2004 02:37:01
 Re: MF35 Lift question in reply to sibby(Aus), 09-19-2004 23:59:19
I had the same problem with my 35.
I had the same universal 10w-30 in the engine and gearbox.
The lift was much better when I replaced the gear oil into a single grade 50w.
William Bos
09-20-2004 06:37:43
 Re: MF35 Lift question in reply to Michael(Sweden), 09-20-2004 02:37:01
Hi,
MF calls for 90w hydraulic mineral oil in these 35's. We have had a hard time finding 90 mineral, so we run 100w mineral and everything works great!!
Take care
Will
Mike(Sweden)
09-21-2004 02:19:55
 Re: MF35 Lift question in reply to William Bos, 09-20-2004 06:37:43
What happen's when the temperature is low does it work properly even then?
mikeb
09-21-2004 20:31:12
 Re: MF35 Lift question in reply to Mike(Sweden), 09-21-2004 02:19:55
WOW!..Thanks for all the responses. Hopefully someday I will be able to return the favor to someone else. Anyhow, my first tractor, am still waiting on my shop manual to arrive. Dont even know yet where to fill up fluid(trans/rear case, ect). I see that top cover under the seat. Also, I guess there is just 1 drain plug for trans/rear case fluid?..Got a lot to learn..Thanks again everyone.
Mike(Sweden)
09-21-2004 23:33:05
 Re: MF35 Lift question in reply to mikeb, 09-21-2004 20:31:12
Check out this
Link
It's in swedish but I think it could be useful for you anyway.
