Masey Harris Clipper questions
msb
09-16-2004 20:40:23
What year for serial number 73916 6' pull type Clipper?When did the Clipper 50 first come out?Beside the chain drive on the fan mill and a removable top on the clean grain elevator,and optional swinging hitch and hydraulic lift , what other changes were made on the 50 model?Anyone know?
Harris Guy
09-17-2004 08:28:18
 Re: Masey Harris Clipper questions in reply to msb, 09-16-2004 20:40:23
A fairly accurate date can be found on the large
upper pulley, of the widest belt. There should be a casting date(raised)within months of date
of assembly. I believe the 50 Clipper was out for
'52 harvest. A PTO driven model was about perfect.
msb
09-17-2004 22:01:27
 Re: Masey Harris Clipper questions in reply to Harris Guy, 09-17-2004 08:28:18
Thanks Harris Guy.I assume you are talking about the adjustable cylinder drive sheave?Just bought it here through photo ads.Its in incredibably good condition for its age.It is a pto model Clipper.not a 50 model, but a Clipper 50 book came with it.Have been just told MF 410 screens will work in it? Can you verify that? Thanks,bob
Harris Guy
09-18-2004 15:17:06
 Re: Masey Harris Clipper questions in reply to msb, 09-17-2004 22:01:27
The pre-50 Clipper had the swing hitch. Removing a couple of bolts, made road travel safer. Though
the 410 was rated a decent combine, I did not get
the use of one. Screen cross not verifiable. I
wonder where you will get the header drape canvase for a Clipper? They were $75.00, in '62.
msb
09-18-2004 20:53:19
 Re: Masey Harris Clipper questions in reply to Harris Guy, 09-18-2004 15:17:06
Canvas is in near perfect condition.It does need some repairs to a couple slats and the leather straps soaked with some oil.Now I have to find a riveter and some copper rivets.Used to have a riveter,rivets and a Stewart Warner hand held tach.One of those things, I don't remember what happened to either.I plan on cutting 5 acres of wheat with it next July.
