101 Super
JC from PA
09-14-2004 22:27:04
Who sells the best manual for repairing/restoring a 101 super?
Why is fuel coming out of the intake manifold where it almost connects to the exhaust manifold?
What are the best modifications to make for pulling? What combinations are you pullers out there winning with? Thanks to all!
MH55
09-17-2004 18:10:32
 Re: 101 Super in reply to JC from PA, 09-14-2004 22:27:04
Good question... I used the factory parts and service manuals... reprints for the dirty shop...
Is the gasket between the two manifold halves missing or rotted?
First: Bore out the block and install F244 pistons.Or just go to a junkyard and find a F245 (had bigger bearing journals) If you are really serious offset the bigger rod journals and gain a tiny bit of stroke by running 244 rods and shaving the tops off the pistons to fit the cylinders at TDC...
Second: Block off the heat passage in the 2 piece manifold and install 44 carburetor...
Third: Adjust your tractor to run the max RPM allowed by your local club. I have seen these motors running 3000+ RPM...
Fourth: If you are really really serious Build a high compression 44 special... Just kidding...
Derrick Otis
