Tuneup Problems MF 202
todd
09-12-2004 18:32:29
Had a rough running motor so rebuilt the carb it helped a little not much. Then put electronic ignition helped alot. Finally installed new plugs. Ran great for about 3 days then started missing again. Help me before I lose it.
Roy Suomi
09-18-2004 22:21:53
 Re: Tuneup Problems MF 202 in reply to todd, 09-12-2004 18:32:29
Did you use Champion plugs ??? If so, pull 'em out and throw them as far as you can..Use another brand Motorcraft, AC , I had a Gardner Denver air compressor with a continental 6 cyl. engine. I tuned it up using "Champs" and it ran one time real well then was hard starting after that. after checking everything else , I decided to try another set of plugs. Darned if that didn't solve the problem. Since then I've run into several cases of no running or poor running engines, changwe brand of plugand they run first time everytime...I'm R.S. and I approve this message..
