152 Deisel misses after 1600 RPM
Jojo
09-09-2004 11:23:57
My brother has a Perkins 152 deisel that misses after 1600 RPM, idles like a champ, any ideas out there? Thanks,Martin.
Phil H Munson
09-12-2004 08:18:55
 Re: 152 Deisel misses after 1600 RPM in reply to Jojo, 09-09-2004 11:23:57
Make sure you are getting sufficient fuel at high RPMs. You may have partially plugged filters and or a line restriction causing this condition. Best, Phil
mowr
09-09-2004 19:28:34
Sometimes a high speed miss is related to late injection timing due to wear in the timing gear train. To check for this, you could try advancing the pump timing a little at a time and see if the upper rpm range smooths out. Of course, you don't want your real ignition timing to exceed the factory recommendation or engine damage can result.
C. T. in Oklahoma
09-09-2004 11:48:06
Mine was related to air intake. The hose to the air breather was old and collapsing at higher rpm's because it was to weak to handle the demand. C. T.
