MF20 front axle grease fitting won't take grease
tginVA
09-07-2004 13:58:51
I have an industrial MF20. The front axle grease fitting won't take grease. I can remove the fitting and pump grease through it. I put it back on the tractor and it won't take grease. I am using a hand pump grease gun. Any suggestions?
pbutler
09-12-2004 18:05:43
 Re: MF20 front axle grease fitting won't take grea in reply to tginVA, 09-07-2004 13:58:51
I have the exact same problem on a 255. I have tried jacking up front axle and lubing while someone swivels it but still not having a lot of luck.
mowr
09-07-2004 19:43:28
With the fitting out, see if you can use a small metal wire or tool to probe the grease hole for dirt that could be in there. Once that's clean, put the fitting back in, put a jack under the front center frame of the tractor to take the weight off the axle pin and then see if you can force grease through. Usually, your symptom results from a clog of dirt and rust.
