Jerky hydraulics
paddy
09-06-2004 06:30:21
Have a 1978 MF590 (same as 290) lift arms shake / jerk badly when lifting - whole way up and at top - suspect hyd pump valves but want to make sure before splitting tractor. Any ideas? I've seen some suggestions about flushing/ changing oil, cleaning filter and checking master control spring - has anyone any success? Can I tell anything from attaching a pressure gauge to test port?
Thomas
09-06-2004 12:02:34
 Re: Jerky hydraulics in reply to paddy , 09-06-2004 06:30:21
Change the strainer before going to town on it.
To test the top draft spring and linkage remove the top link and attach the implement directly to the rear axle casting with a chain, without toughing the control beam. If lift is now OK then that isolates the trouble.
Connect a pressure gauge to the trailer tipping port (not the spools if fitted, theres a service pump on tractors with spools). Move the lever to constant pumping, if it's valves you will see the needle moving like a windscreen wiper. If so fit a complete pump overhaul kit, it's easier and quicker than changing valves and doesn't cost a lot.
paddy
09-07-2004 05:15:09
 Re: Jerky hydraulics in reply to Thomas, 09-06-2004 12:02:34
Thanks Thomas - I will let you know how I get on - I assume that connecting pressure gauge to test port in the transfer plate is the same as trailer tipping port?
