MF 2745 trans trouble
Nick
09-05-2004 18:39:29
Can anyone tell me what would cause this tractor not to go in reverse? You can feel the gears meshing when you shift, but when you let the clutch out it won't move. All other gears work fine. It is 24 speed multi power. Thanks, Nick
TN FARMER
09-08-2004 07:07:02
 Re: MF 2745 trans trouble in reply to Nick, 09-05-2004 18:39:29
I HAD A 2745 WITH A 24SP IN IT, THERE IS A RUBBER BUSHING IN THE LINKAGE UNDER THE CAB,AND IT WOULD STRIP OUT AND WOULD BE HARD TO PUT IN GEAR AND FORWARD TO REVERSE. I ALSO WENT INTO THE 24 SP, AND SPENT SOME MAJOR BUCKS. THE OLD TRACTOR SHURE WOULD PULL, SOLD IT AND GOT A 4440 DEERE.I HOPE THIS HELPS TAKE A LOOK AT THIS BUSHING/COUPLING.
bad news
09-06-2004 15:35:46
Once owned a 2805 with 24 speed. Was 'told' that when Reverse goes out, your Multi-Power is going bad. Don't know if that is your problem or not. "marlowe" on this site knows the 2000 series very well. Good luck.
marlowe
09-06-2004 18:01:15
 Re: MF 2745 trans trouble in reply to bad news, 09-06-2004 15:35:46
it's been a long time since i worked on the trans in a 2000 and sure would not like to give the wrong info. sorry . one thing to check is your trans. pressure on the power shift
Nick Jackson
09-06-2004 20:36:54
 Re: MF 2745 trans trouble in reply to marlowe, 09-06-2004 18:01:15
Thanks for the replies. You may be on to something with the pressure suggestion. When shifted into low range and reverse, the "power shift clutch oil pressure" light comes on. This sounds like the problem. Any suggestions as to what could cause this? Thanks for any advice. I am completely stumped by this. Thanks again, Nick
bad news
09-07-2004 06:15:59
 Re: MF 2745 trans trouble in reply to Nick Jackson, 09-06-2004 20:36:54
If I remember correctly(50%), there are two hyd. pumps, the 'main' and the 'aux'. I "think" that the Powershift is powered by the 'main' pump, right side, in front of rear axle, should be a port or threaded plug to check pressure, probably need a book to find it. The pump, I'm told, is not that hard to remove/ohaul/replace but requires draining about 70+ gallons of hyd oil.
P.S. I 'suspect' marlowe knows more than he admits to ;-)
holm
09-07-2004 10:47:47
 Re: MF 2745 trans trouble in reply to bad news, 09-07-2004 06:15:59
I would guess that you have a linkage problem under the cab. Have someone watch to make sure the shaft going through the cover is actually turning all the way.Even if you have no hyd. pressure the tractor will still drive, as the intermediate part of the trans needs no oil pressure to operate. That means that if you have no oil pressure the trans will automatically go to intermediate. Good luck. holm
